- Joined
- 7 Sep 2022
- Messages
- 4,722
- Reaction score
- 1,371
- Country
I meant I was going to walk into store, buy a battery and post it to yousadly aldi no longer do click and collect
This is deadly serious sir!
Did you read the page that said batteries would be on sale on Sunday?
Did you go to Aldi on Sunday to buy one?
Or are you an idiot?
This allows them to terminate the usability of a device at a moment of their choosing. This is why I avoid battery devices. If I must get something with battery, I treble check to ensure the batteries are a commonly available standard.
I would suggest the OP throw away the piece of junk and get a corded one. It would likely to be cheaper than buying batteries. This also reduces risk of lithium battery fire burning the house down.
Phew! So I'm off the hook.Surely only an idiot would buy a device without a battery?
We only have mains power c. half way down the garden, and from there my longest extension lead would stretch to the bottom of the garden, but only in the middle. If I needed to get to either bottom corner of the garden I needed to use two extension leads.Battery powered is very useful, especially so for a quick job - versus the possible alternative of spending much more time getting corded item out, plus extension leads
that sounds a great idea! can i send you a postal order for it?I meant I was going to walk into store, buy a battery and post it to you
I was in my usual Aldi on tuesday, no batteries for sale!Did you read the page that said batteries would be on sale on Sunday?
no! because the grinder was on offer!Surely only an idiot would buy a device without a battery? Anyway I think this is another wind up.
sadly I need to use it in places away from mains power. otherwise i would use my Makita 4 1/4"I don't think it's right to treat people as idiots because they made a mistake. Batteries are a common trap some manufacturers use as an exploitation. This allows them to terminate the usability of a device at a moment of their choosing. This is why I avoid battery devices. If I must get something with battery, I treble check to ensure the batteries are a commonly available standard.
240V power tools are much better and reliable should you have access to mains powerEach manufacturer uses different batteries, as any sensible person would expect. The idea being to tie you in to buying their range of drills, grinders and etc.. The OP's complaint is not at all valid, because though the batteries are not always on sale at Aldi, they quite frequently are available. Even if not for sale at the time needed, there are other sources.
Battery powered is very useful, especially so for a quick job - versus the possible alternative of spending much more time getting corded item out, plus extension leads, for a job which could be done in two minutes with a battery powered.
What is now obvious, is that the OP simply started this thread as a wind up.
