Or spit on the valve & watch for a saliva bubble burstingYup, slow puncture, or tyre not seating on the rim well and letting air by, or valve letting air by? I would spend your money on getting a local tyre fitter to sort it. You might be able to test the valve by getting a mixture of washing up liquid and water, dipping your finger in it, taking the valve cap off then wetting the top of the valve to try and form a bubble to see if a bubble forms and gets bigger. Have you hit the kerb with this tyre recently? Can you see if there's a nail in the tyre? How old is the tyre?
Very good advice B. If the spare looks a bit ratty or it's a space saver (narrower that the normal ones) you really have to get this sorted ASAP or it could be dangerous using the spare for anything but getting you to the tyre fitter (if the tyre is the issue).Check the valve then fit the spare wheel if the valve is ok......don't let the tyre go down to 8 psi there's a chance of rolling the tyre off the rim.
John![]()
Is there a Wilko still open near you?
