- Joined
- 1 Apr 2016
- Messages
- 13,606
- Reaction score
- 550
- Country
So you are upset at a concept. An idea.
As I say do some research it'll save shooting from the hip.
Don't make yourself look gormless tonight, when you get on that thunderbox tomorrow do a bit of research.I have there is nothing out there its just a concept and you seem to have run with it.
If you cannot defend your stance then you have no view on it other than it being superficial so easy to dismiss. If you truly believe in it then you would argue for or against it. Either way it seems you have been taken by the marketing spin - be wary of what it says on the tin.
Don't let them fill your head with ideas - let them explain the issue with concrete evidence.
Have you been in the Euston underpass?take 2 mins to learn a tiny bit about the weather and you will understand a lot more about why a tax on apparently 10% of vehicles in Greater London will make zero to negligible difference to air quality.
I could have cut it down to one but I wasn't in full on Marxist mode.
Last I checked. It wasn’t in the expanded ULEZ zone.Have you been in the Euston underpass?
If only we had a national system that charged vehicles accordingly. Perhaps an annual charge based on emissions and the another based on usage. Probable too hard to implement. Oh wait…
So you started going on about Greater London, and now you've changed your mind.
Or the whole country
