Ps I’m not changing my habits
Then you will eventually pay for your habit. Octopus would have charged 150% of the fixed cost per Kwh between 17:30 ND 18:00 today, but only 75% an hour later.
I have just been forced to get a smart meter fitted, told the law changed 6 weeks ago and now I can't get a feed in tariff without one. ...
What 'law' would that be? Kind Regards, John
I thik you're probably too quick/prepared to believe everything you are 'told'. To the best of my knowledge, there certainly isn't any law that requires one to have a #smart' meter under any circumstances.He just told me law had changed, ...
As I've often said to the anti-'smart' meter people, although there is seemingly at present no compulsion for a consumer to have a 'smart' meter, I do not doubt that it will be increasingly the case that suppliers only offer attractive tariffs to those who do have such meters - and that is a commercial decision for them to make.I have since looked on the web and some companies do not say they need a smart meter, but they offer half the rate to those who do require a smart meter. Scottish Power it seems require "You must have a Smart or AMR meter that can obtain half hourly readings and consent to Scottish Power taking them."
I don't believe that is 'their' thinking.They can, never will never reduce usage - what they can help with is in reducing the peak loads.
What do you think they are actually trying to achieve?Why aren’t those in power , pardon the pun, just come clean about what they are trying to achieve ?
'Sadly', in some senses (I was rather looking forward to some 'interesting exchanges' with them..... In reply, I have said that I would 'mind' doing as they ask, I pointed out that the primary reason i agreed to their fitting a 'smart' meter was their assurance that it would remove the need for me to provide them with readings (obviously difficult for me, since I am rarely there) - so that if they want readings, they will simply have to send a meter reader to get them - and adding that, since there is only occasionally someone there to provide access, the meter reader will have to make an appointment to visit at a date/time which is convenient for me! ... I await their response to my reply![]()
In any event, as I have often said, I would have thoiught that that could have been achieved much more simpoly, quicker and cheaply (and maybe more effectively) by a campaign of education about the energy usage of various loads than by the incredibly expensive and protracted deployment of 'smart meters'.
One can try to achieve that my the use of 'carrots' or 'sticks'. You are suggesting the latter but, traditionally, dual-rate (and more complex) tariffs have basically used 'carrots' - with the 'peak time' cost being only slightly more than with a single-rate tariff, but the cost at 'off-peak' times being a lot less than with a single-rate tariff.To enable the energy companies to charge more at peak times in the hope that people delay using power at "peak" times
Sure, it is obviously desirable that demand be as constant (throughout the 24 hours) as possible. However if, in the manner I described, people are persuaded to reduce their total energy consumption, that would mean that the maximum load the network had to service would be lower.Generating plant has to be there, and be available to match the maximum load, at other times it is just expensive wasted capacity.
OR, as I've just written, to charge less for usage at off-peak times. As I wrote, what matters is that energy is cheaper at off-peak times, and one does not necessarily have to increase the price at peak times - at least, not a lot. As I said, one can use 'carrots' rather than 'sticks' (and that is advantageous psychologically, hence in terms of 'PR').The only way to persuade people to avoid the peaks for their own consumption, is by monitoring and charging more for peak usage.
Indeed - but, as above, the cost 'during peaks' does not necessarily have to be particulaely high, provided that the off-peak cost is lower. As I also just wrote, 'smart' meters offer the advantage of being able to do this dynamically but crude time-based switching, on the basis of (approximately) known current patters of usage can go a long way to achieving what is wanted.The only way to do that is via SM's, reporting consumption every 30 minutes, charging more during peaks, less during none-peak times.
I have to keep reminding you that smart meters are installed by order of the government; not the energy companies.
When in recent history has the government used carrots?
Whilst that's literally true, I strongly suspect that it would have happened before long even in the absence of government edict. Generators/suppliers have an interest in 'evening out demand' and, long before anyone had heard of 'smart' meters were offering financial incentives for using off-peak electricity. Technology which enables dynamic changing of TOU tariffs allows them to refine that process.I have to keep reminding you that smart meters are installed by order of the government; not the energy companies.
Whenever there is an upcoming electionWhen in recent history has the government used carrots?
As I wrote, I think they genuinely believe (quite probably mistakenly) that they will result in a significant reduction of total energy demand, hence a bit of a help towards there (probably unachieveable) 'comittment' to a 'net ero' target date.It seems the smart meter reports every half hour, where the existing system may have a few minutes delay due to server being in China, it is far more rapid to the smart meter so seems a little pointless.
As said it is the goverment who wants them, and one has to wonder why.
I thing the 'other reason' (in the eyes of government) is what I have mentioned above and I rather doubt that it is anyuthing to do with wht you suggest.However with smart meters they can select who is turned off. So the venerable can be left unaffected by cuts. I can see no other reason why the goverment want smart meters.
Maybe not your usage. One of my neighbours used to use their tumble drier extensively, throughout the year, essentially just out of hsbit. Wheen they got a 'smart' meter and discovered how much it was costing theem, they re-discovered clothes lines and clothes horsesBut energy saving means a tumble dryer takes a lot longer, so setting run times to use solar power is not that easy. So can't see smart meters changing our use much ...
Definitely not.It’s my understanding that the government pay for each SM installed
