In the absence of a proper RJ45 tester is it worth checking the continuity with a long piece of wire,
Wouldn't it be easier to buy ready-made cables in (about) the right length?
You could use the mains earth, in place of the long wire.
At the far end, an old disused router / modem, could be repurposed to provide a wifi access point, and three wired LAN outlets. People get a new one of these, each time they change broadband supplier.
You don't need a router, and using one could cause issues that will be difficult for you to resolve, if you end up with two devices on your network attempting to dole out IP addresses
Can you show me an example?Sure, if it's even possible - we don't know what old cark is lying in a drawer and not saying we wouldn't help with it either, but if I was playing tech support at the other end of a text interface to a non-techie, talking them through finding or recovering the password for the router they might not even be able to identify, with a custom firmware, and only one laptop that needs to be variably connected between the LAN side of the working router they use to post on here and the LAN side of the old router..
..all to save about 7 quid* and end up with a 100meg 4 port..
I wouldn't bother!
(* price revised from a tenner having found a reasonable few tplink gig 5 port switches going for this amount![]()
I wouldn't bother!
