Thanks, very helpful. I am the leaseholder, yes. The freeholder is referred to as the Landlord in the lease, so that's who I'm referring to. As I have said, it's a long lease. I'm happy to get it replaced based on what you say. Here's the request from the Landlord:AIUI there's no LEGAL requirement to upgrade the existing installation.
It was regs-compliant at time of install.
There is probably little to no fire risk from that fusebox as it's made from a Bakelite type of plastic rather than thermosplastic that some later boxes were made from that could melt at far lower temperatures and feed in to a fire starting within a consumer unit. (Mind so will the plastic coatings of the cables to the circuits).
Do you own the Lease for this Property or rent the Property from the owner of said Lease? Is it the Freeholder of the Building (or his Managing Agent) that is trying to bamboozle you with this requirement, or your Landlord if you are a Tenant and rent? Get the request and reasoning behind it in writing?
Now in all fairness you would be very wise to consider updating that Consumer Unit with a modern one. Perhaps even sort out some extra circuits and rewiring. (e.g. add mains interlinked smoke alarms). That independent electrician has simply quoted for a modern equivalent of the current 4 way board. The maker is Hager. Each of the 4 circuits will now be Residual Current and Overload protected which is better than what you have now. Only the metal enclosure for the new consumer will affect the fire safety / spread --- and only if installed correctly with such matters in mind.
Here are the two reports for your installation.
You will note that there are several items that are noted as being in need of urgent improvement, and I would be grateful if you could make arrangements for dealing with these in the near future. The lack of RCDs is a particular insurance risk as a short-circuit could cause a fire.
You are, of course, free to choose another electrician to do the work, provided that they are a Competent Person and can self-certify their work, with paryticular reference to the recommended replacement of your Consumer Unit (formerly known as a fuseboard).
I will need to disclose to insurers that there are some C2 works recommended for your flat, and they may impose a time limit for doing them."
Easier for me to get RCDs, rather than argue about it, and it sounds as if it's worthwhile anyway. So I'm hoping if I replace the fuse board he will shut up. A lot of the other items identified as C2 should not be so, according to my independent electrician and I'm more inclined to argue over those if I have to.
