Do I need a new electric CU for (Rental) EICR? (Ed.)
If you mean 'total ("100%") immunity' (presumably in everyone who receives it?) what example of a vaccine which does that can you cite?
I will admit I thought once we were vaccinated we could not catch the item, like when I got the yellow fever one, but it did have a time limit, the flue jab was first where we needed a new one every year, and could still catch it.
OK but the rental laws specifically states the 2018 Regs, not subsequent ammendments, therefore to comply with that law an inspection must be compared to that particular version.
You might, at the time, suggest recommondations for items include in subsequent ammendments and again items you personally recommend to enhance safety etc and I think that most of us would commend you for that.
What you must not do is to suggest such ommisions are defects when compared against the standard required.
You could end up in the middle of a right arguement or even get sued.
It does refer to the 18th but then says earlier editions may not be compliant but may not need upgrading.
So inspect to the 18th and liberal use of C3’s is in order
How can you get sued if you apply this logic?
No EFLI. I disagree.
Anybody can catch owt umpteen times once they had it but many things you less likely to get it 2,3 or 100 times. Is the way I understands it anyway. Often if they do get it again its not as bad as it might otherwise would have been.
Someone with more appropriate knowledge might know better than me though.
My understanding of the Flu jab for example is "say for instance as a theoretical example" - A room/area of 99 people are exposed to an infected person for an amount of time. 66 might actually catch the flu and 33 might not. Nobody had been vaccinated.
Same scenario but all of those 99 had been vaccinated. This time 33 might get the flu but 66 might not,
In each case nobody is immune from catching flu but nobody is guaranteed to get it.
In comparisons the vaccinated risk is about half compared to unvaccinated risk.
One year the numbers might approx tally and I think most would include it as a quite successful vaccine based on figures.
If you inspect in accordance with ammendment 1 or 2 and include something that is in the non ammended version and accordingly you defect it and code it.
Example - if such a law was around say 50 years or more ago and you had incredible future insight and defected an installtion for no main bonding back then because you absolutely knew that it would be a defect in the future (nowadays)
That is the definition of a vaccine.
Not in my book it isn't, regardless of what dictionary definitions you may throw at me. You seem to think that a vaccine will give total immunity to a disease (maybe even 'for ever'?) in everyone it is administered to. No matter how hard you try, I am confident that you won't find any vaccine for which that is true.
A 'good vaccine' will provide immunity from infection to a high proportion of recipients, at least for some period of time, and in those who develop the disease despite vaccination, the disease will often be milder and/or shorter and/or less-easily transmitted.
The technical documentation for any vaccine will contain statements such as in these few examples:
Typhoid
As with any vaccine, vaccination with TYPHIM Vi may not result in protection in all vaccine recipients.
Yellow Fever
As with any vaccine, vaccination with STAMARIL may not protect 100% of vaccinated individuals.
Hepatitis A
As with any vaccine, vaccination may not result in a protective response in all susceptible vaccinees.
MMR
Vaccination with M-M-RvaxPro may not result in protection in all vaccinees.
.... etc. etc.
Small pox?
Smallpox vaccination certainly did not give "100% immunity". What it did do was to give immunity, at least for a period of time, to a high proportion of recipients. As a result, the number of people infected at any point in time dramatically decreased, hence a dramatic decrease in those able to infect others, with progressively reducing number of 'infective' people able to transmit it in each 'generation' of transmission - until, eventually, there was no-one 'infected' left to infect anyone else.
There is no current documentation for any smallpox vaccine, since nowhere in the world is it available for routine clinical use. However, the CDC (one of the world's most authoritative sources on such matters) currently says:
Historically, the vaccine has been effective in preventing smallpox infection in 95% of those vaccinated.
They also say (relevant because some people in this thread have been talking about 'everlasting immunity') ...
Smallpox vaccination can protect you from smallpox for about 3 to 5 years. After that time, its ability to protect you decreases. If you need long-term protection, you may need to get a booster vaccination.
Although no longer used routinely/'clinically', smallpox vaccines still exist, but to thee best of my knowledge are only given to people in the very small number of labs around the world which still have, and work with, live smallpox viruses.
Yep that falls in line without my overall way of looking at it to a degree and without numbers or details, just more of an approx overall thinking of how vaccines might well be "quite" effective in many instances.
If someone incinerates me at a good distance they might be very sure, near 100%, that I am then unlikely to transmit/receive any viruses etc.
EFLI - some dictionaries actually list Electrocution as Electric shocks but I do not , Electrocution is death caused by electric shock/current
Earlier editions is open to interpretation but pre 16th, around 20 years ago would have been a sensible cut off but as we all know this was put in place by numpties who didn’t have a clue including the ex ceo of Certsure.
Shame our observations prior to it being made law were ignored
I remember discussing all this with a pal who’s a spark and we couldn’t believe what a hash had been made of something that should have been easy to write and define
What do you mean by "the 18th" - BS7671:2018 or Amd 2 thereof?
I seem to recall that you said that inspection should be to 'the current edition' (which is Amd2), didn't you - but if you identify things (even if only C3) which are non-conformant with Amd2, but which would have been compliant with BS7671:2018 (as required by the legislation), then you would be acting outside of the instructions of the legislation.
Ok, so something which does not do that is what?
A 'not-so-good', but, quite possibly a nevertheless 'appreciably-better-than-nothing vaccine' (or, as with many, a 'much-bertter tha-nothing vaccine') - but still 'a vaccine'.
Certainly in terms of 'routine vaccines', you would never see one that only protected a small proportion of those receiving it (a 'bad vaccine') , because it would never be 'released' - there have, for example, been many anti-malaria vaccines which, in trials, have not proved effective enough to be 'released' for routine use.
Vaccines are no different from any medicines - none do 'exactly what it says on the tin' for everyone who receives them, but we still call them medicines - or. more specifically, anti-diabetic medicines, antihypertensive medicines, anti-cancer medicines, anti-depressants etc. etc. Just as nothing we call 'a medicine' (or one of those specific types of medicine) is a 'perfect medicine', so are none of the things we call vaccines 'perfect vaccines.
Quoting the PRS legislation its the 18th edition - not AMD 1 or AMD 2 or worse the 19th edition.
So we are inspecting to a previous edition - which is clear.
