I'm not sure, I'd assume so yes... Could I use a timer to do this? Again have not a clue..
All I know is it's how it was left and I've run out of money to get it done.. so really need to get this heating going
You need some advice from an expert on here. I'm just throwing this out as an idea. But normally a mid-position valve is used for CH and HW cylinder using a two channel programmer. I wonder if there is a way to make it work instead with two heating zones. In the usual set up, the signal from the terminal labelled "HW OFF" moves it to the third position.
