Not at all no. However, have you ever tried mixing Imperial plumbing stuff with metric? As I said, metric and imperial stuff is distinct and different.Obviously that would cause you some confusion noseall
Do you even know what 15mm is in Imperial?
Cumulatively, the differences can be problematic. For instance 16" is not 400mm, 18" is not 450mm and 24" is not 600mm. By the time you have several incremental measurements at one or the other, then the difference is huge. They DO NOT mix. Reverting back to Imperial would be idiotic and catastrophic.15 mm is half inch in pipe size there is no difference
There is how ever a difference between 22mm and imperial equivalent hence why there are adapters to connect onto it via imperial compression rings or solder adapters
Irrelevant. Unless of course you are suggesting that lawyers and lawmakers may start trying to mix metric and Imperial for some bizarre reason?Doubt you have noticed but The Speedo in yer car reads mph
As do the speed signs in your area
The court system in the UK still use mph in speeding prosecutions
Most burger out let’s in the Uk usually under stand the term quarter pounder when you ask for a burger
Although if it’s run by some French bloke they probably would not
Doubt you have noticed, but most modern speedos have mph and kph scales.Doubt you have noticed but The Speedo in yer car reads mph
I can change mine with the flick of a switch. I doubt I'll ever take it across the water though.Doubt you have noticed, but most modern speedos have mph and kph scales.
Do the lights change as well?I can change mine with the flick of a switch. I doubt I'll ever take it across the water though.
No idea.Do the lights change as well?
Probably not then.No idea.
Lol.
Audi Matrix technology disputes that.Probably not then.
I'm in no position to argue.Audi Matrix technology disputes that.
Because that would be utterly stupid. As was the ridiculous suggestion by Reesmugg.Not suggesting any thing of the sort
Edit.The use of some Imperial measurements has never gone away
Brexer shmucks.
