If the LED lamps/bulbs are cheap ones (with just a capacitor and bridge rectifier to control current) then any flicker will be at 100 Hz,the same as a fluorescent tube, but if they have was is effectively a SMPSU, then it could be a much higher frequency.Going very slightly off topic. Fluorescent tubes can make a spinning circular saw blade look stationary. I wonder if any LEDs flicker at the same frequency.
The difference is, of course that, whatever the frequency, a smoothing capacitor can be used to reduce the amount of flicker (theoretically,to any extent one wishes), whereas with a fluorescent tube with a traditional 'magnetic' ballast, the only thing reducing flicker is the 'persistence' of the phosphor with which the tube is coated. I presume that 'electronic ballasts' probably resulted in much higher frequency 'flickering'.
