Running a cable around a corner
I believe the top down view and the photo agree exactly, assuming the worktop to the right does run along the 3rd wall (the wall with the window)
Maybe, but that 'third wall' is irrelevant, since the sockets in question are on the 'first wall' and the 'second wall' (which intersect at a single corner).
I continue to be amazed that people are still arguing about this :)
I didn't say anything other than the photo confirms the accuracy of the top down view, albeit with making an assumption. I don't see how you interpreted it to be anything different.
I'm amazed that you have stated the 2 images don't tally when they clearly DO.
The top-down diagram is presumably only 'accurate' if there are cupboards above that worktop (across the window)? It's not totally clear from the photo where the boiler is, but I presume it's in the cupboard above the 'red' socket'?
As I keep saying, what IS crystal clear from that top-down diagram (presented in post #1) is that the two sockets are on walls which intersect at a single corner (with no 'third wall') between them - which is why I don't understand all the argument.
The two diagrams? The second one is clearly not a true 'front elevation', since it has been 'folded out to make it look as if the walls with the two sockets are in the same plane, whereas they are actually at right angles - but, if one accepts that, it again confirms (as in the top-down view) that there is no 'third wall' between the sockets..
It remains the case that ....
What it totally clear from the photo is the presence of 2 worktops, and no wall cupboards to the left. (Yes relevant)
As I keep saying, (For at least the 11th time - Sunray) what IS crystal clear from that top-down diagram (presented in post #1) is that the two sockets are on walls which intersect at a single corner (with no 'third wall') between them - which is why I don't understand all the argument.
I didn't mention the front elevation:
At this stage I think it's only you aguing anything.
What it totally clear from the photo is the presence of 2 worktops, ...
True, but so what?
... and no wall cupboards to the left. (Yes relevant)
To the left of what, and why 'relevant'?
Fair enough - so what were the 'two images' you were talking about?
Ever since my initial post (#2), all of the countless messages I've posted (this one will be #50) have been in response to people arguing about the fact that what I said in that post may not have been correct (although it transpires that it was correct).
True, but so what?
Just pointing out your observations and subsequent comments don't relate to the diagrams
The left part of the drawing and relevant to your comments about cupboards above worktops and lack of interpreting the drawing
just incase you don't understand my comments, a reminder from post#49 or to put is another way; the post you responded to.
Ever since my initial post (#2), all of the countless messages I've posted (this one will be #50) have been in response to people arguing about the fact that what I said in that post may not have been correct (although it transpires that it was correct). (>12 Sunray)
Without going back over the whole thread to double check, my feeling is until the last few posts; posters had been 'arguing' more about the understanding of the situation than your, or anybody elses, righteousness.
So how about stopping this nonsense?
Everyone has being going on and on about the possibility that the situation was initially being misunderstood because of a lack of clarity in the OP's diagrams (a lack of relevant clarity I do not personally see, particularly in the 'top-down' diagram), even long after the OP presented us with a photo (in post #23 of 51) which confirmed that there had not been any 'initial misunderstanding'
Your behaviour has convinced me that such is the appropriate course. I have no desire to remain involved in this 'ruined thread'.
