Which replacement tube light fitting?
17 Jan 2015
Hertfordshire
Could I pls have some recommendations as to what I can replace the unit which houses these tube lights with a long life LED one instead?
I would like to get an idea of product costing before I buy it and get a professional to install it.
Thanks.
Thanks.
Go to TLC and buy replacement fluorescent tubes. Despite what many people claim LED versions are not equivalent.
I've worked in a number of places where significant sums of money have been wasted converting to LED and back to Flou.
If they work why replace the tubes
See https://www.sparksdirect.co.uk/blog/fluorescent-lamps-tubes-phased-out-september-2023
Also, look up "Osram SubstiTUBEs"
It might be noted that the light output of the LED “SubstiTUBE” is (only) 1800 Lumens whereas the light output of an equivalent Fluorescent Tube is 3250 Lumens,
However, it should also be noted that the light output of the “conventional’ Fluorescent Tube is at 360° around it - and almost half of that is “upwards” and, hence, “wasted” by the not very efficient white reflecting surface above.
In comparison, the light output of a LED tube is almost entirely “downwards” or “outwards”..
Because of this, a LED tube is likely to appear to be just as ‘bright” (if not more so) as any Fluorescent Tube which it replaces.
In addition, these quoted Lumen values apply when the tubes are new.
A “Conventional” Fluorescent Tube “dims” over the years more than does a LED Tube (plus, its “Ends” also blacken.)
How would I know as a lay person whether there tube has gone or if it’s the starter (if I don’t have a replacement tube to hand to try)?
The reason I’m considering replacing the tube holder is because I presume the tube has gone and I might get an electrician in anyway for some other minor works. I own a dental practice and we have a old tube in the disabled and only bathroom and when that goes it’s going to be a headache for me to change it quickly.
I’d rather have a LED one that lasts 5-10 years since the light is almost always left on during the day consuming 70-100 watts v 15-25 watts. And we have several of these in the building with no backup light in critical areas.
What does the /840 represent? Can someone pls recommend some appropriate lengths to match?
@SUNRAY is correct in the main output and life from a fluorescent tube is better and same as the LED's that replace them. And also @FrodoOne is correct the government feel the danger from mercury is greater than the danger from arsenic so are phasing out fluorescent tubes.
So if the ballast is wire wound, which means it has a starter then any LED tube correct length can replace the old fluorescent, if however no starter so likely an electronic ballast then there are some LED tubes which will work, but not all, however since the electronic ballast means the fluorescent uses far less energy for light output, and the tubes last longer, if an electronic ballast you may as well stay with fluorescent for as long as you can still get them.
So 70 watt will be 6 foot tube, the LED replacement is one expensive around £30 and two likely only 40 watt with a 4400 lumen output, where with a wire wound ballast the fluorescent is around 6000 lumen output and an electronic ballast around 6800 lumen output, so if you need the lumen output then better changing the whole fitting. Even if you don't need the output still likely two LED fittings will replace the single fluorescent, so you really need to look at room or area and decide what lighting to use.
The 18 watt is different, the cost is down to around £7, again the LED tube will not have the same output to the fluorescent, an 8 watt LED is around 800 lumen, where an 18 watt fluorescent is around 1400 lumen, so again it depends on how much light is required, but where they were fitted was often under counter etc. And the LED strip light is often a better option.
Paying out £7 to see if it will be enough light is not so bad, but £30 you really want to be sure bright enough. I replaced a 58 watt fluorescent with a 22 watt LED, the first tube did not last long, the second tube did better, but I sold house and new owner replaced with down lights. The original fluorescent 1500 mm long (5 foot) was fitted to get the light spread, it did not really need to be that bright, this was common, so often a lower output will do.
I do not like integral lamps, LED's do fail, and better if one can replace a bulb or tube, than have to change whole fitting. But I look at the kitchen which had the 5 foot fluorescent 102 Kitchen Bike.jpg and that ceiling now has around 12 down lights, at around 4 watt each, so 58 watt replaced with 48 watt, but it had a LED tube at 22 watt, and lumen is now around 3600 where was 5000/2100 so half way between the two tubes. Likely looks better, but at £3 each so £36 plus all the work fitting them.
840 is cool white, 4000K.
Both are obsolete so it's irrelevant.
The only supplies today are places which have hoarded stock, and when they are sold, that's it.
If you just want replacements which are the same length then it's just a case of looking for fittings which are the same length - '2ft' and '6ft' in the case of those 18W and 70W fluorescents.
However that's not how lighting is selected - you need to determine how much light is actually required in the various locations and select items to fulfil those requirements.
The length or other dimensions of LED lighting does not determine it's light output - you can get fittings of the same physical size with very different light output. Some of them are less than the same length fluorescent, others more.
Then there is the question of whether linear tube style lighting is actually appropriate or desired.
That's not what the wholesalers are saying.
Equipment must be supported for set number of years, can't remember if 5 or 7 years, so since last year fluorescent fittings were still on sale, so tubes to fit them must be sold that's the law, however as to what tube that is not stated, the really old stuff no problem, it is the more resent stuff which has the problem.
The electronic ballast is far better than the wire wound, and the wire wound was discontinued however the electronic would not work with early LED replacements, I know my son fitted a LED in an 18 watt electronic ballast lamp and it works, without removing the ballast which was a special as it included battery so light auto turns on with power failure, otherwise he would have removed the ballast.
In theroy this
works, however the non power end of the LED is a short circuit, so really the two ends should be wired in series, so it does not matter which way around the tube is put in. Other wise it will be a short circuit which is not what is wanted.
So this 1726982438672.png becomes this
both for magnetic and electronic, so does not matter which way around the tube is inserted. But with wire wound the ballast can be left in place if you want, although less efficient if you do, and the starter is swapped for a fuse which normally comes with the LED tube, and is shaped the same as the old starter.
If the tube is at end of life but starter is good, the starter will repeatdly try and start it and it will flash in a very annoying way, this will put a lot of extra wear on the starter which will soon cause it to fail too.
If the starter is bad, it will keep the filaments at the end of the tube glowing without trying to start it (this puts a lot of wear on the filaments and blackends the end of the tube, and sometimes melts parts starter sockets or plastic parts around the ends of the tubes, you can often cause it to start by removing the starter if the tube is still able to strike as this mimics what the contacts in the starter to. Putting it back in will result in it returning to the previous condition but when the light is switched off and on again, it'll do nothing at all without a starter.
It is normal to change both together, they are probably a similar age and if one isn't bad, it'll have been age prematurly by the one that is. (which will then soon fail, rinse and repeat....) Or course if its been left a while, both may be bad.
Of course, @flameport is right about it all being obsolete, but at the moment theres still plenty of tubes and starters in the supply chain, so you could just change them both this time and just accept that next time around you'll be getting a new fitting
