@SUNRAY is correct in the main output and life from a fluorescent tube is better and same as the LED's that replace them. And also
@FrodoOne is correct the government feel the danger from mercury is greater than the danger from arsenic so are phasing out fluorescent tubes.
So if the ballast is wire wound, which means it has a starter then any LED tube correct length can replace the old fluorescent, if however no starter so likely an electronic ballast then there are some LED tubes which will work, but not all, however since the electronic ballast means the fluorescent uses far less energy for light output, and the tubes last longer, if an electronic ballast you may as well stay with fluorescent for as long as you can still get them.
So 70 watt will be 6 foot tube, the LED replacement is one expensive around £30 and two likely only 40 watt with a 4400 lumen output, where with a wire wound ballast the fluorescent is around 6000 lumen output and an electronic ballast around 6800 lumen output, so if you need the lumen output then better changing the whole fitting. Even if you don't need the output still likely two LED fittings will replace the single fluorescent, so you really need to look at room or area and decide what lighting to use.
The 18 watt is different, the cost is down to around £7, again the LED tube will not have the same output to the fluorescent, an 8 watt LED is around 800 lumen, where an 18 watt fluorescent is around 1400 lumen, so again it depends on how much light is required, but where they were fitted was often under counter etc. And the LED strip light is often a better option.
Paying out £7 to see if it will be enough light is not so bad, but £30 you really want to be sure bright enough. I replaced a 58 watt fluorescent with a 22 watt LED, the first tube did not last long, the second tube did better, but I sold house and new owner replaced with down lights. The original fluorescent 1500 mm long (5 foot) was fitted to get the light spread, it did not really need to be that bright, this was common, so often a lower output will do.
I do not like integral lamps, LED's do fail, and better if one can replace a bulb or tube, than have to change whole fitting. But I look at the kitchen which had the 5 foot fluorescent
and that ceiling now has around 12 down lights, at around 4 watt each, so 58 watt replaced with 48 watt, but it had a LED tube at 22 watt, and lumen is now around 3600 where was 5000/2100 so half way between the two tubes. Likely looks better, but at £3 each so £36 plus all the work fitting them.
