We had a Worcester Bosch 4000 boiler fitted a few months ago - all pipes go into the boiler through a mounting plate. We recently got a visit from an electrician for some work and he says the boiler needs to be bonded ('equipotential bonding') using 5x bonding clamps; the previous 20+ year old boiler was bonded, but my understanding is that new boilers don't need this. The boiler is in a cupboard off the living room; it's wired to a new consumer unit with RCD protection. He quoted £75 for the work - which IMO seems expensive given there's an earth cable rolled up next to the boiler which goes back to the consumer unit (so if required, I imagine bonding would take less than an hour).
For additional context: The gas pipe into the property is bonded within 60cm of the gas meter. The water pipe into the property is also bonded at the point of entry into the property (the ~1m pipe before entering the property is plastic tho; all the rest metal as far as I can tell).
Does the boiler need to be bonded? If not, how can I argue this with him? We've got some other electrical work we need him to complete urgently including an EICR test.
Thanks in advance!
Thanks in advance!
