How will you "turn off the boiler" ?
The frost stat will overide any timer(Tado) settings and it is not advisable to let your external (garage) boiler freeze
Surprisingly low, if each peak is a whole day's usage. I'd suspect an issue with the Tado readings.
Gas usage for December in my 3-bed house averaged ~50kWh per day.
They are invaluable to me as I use them to turn off the heating on several rooms we do not use, or turn off heating in rooms at certain times of day on a schedule.
But your Octopus gas usage suggests that something is turning your boiler on periodically all day long. How have you setup the heating schedules in Tado?
Because you said there is no point in heating one room at a time and that implies the system is out of balance and the radiators are not heating in unison!
It varies room by room. But essentially I only have my study heated during the day and then by evening the other rooms we use are heated ready for when everyone gets home. During the night only the bedrooms have a temp set to stop people freezing overnight.
