- Joined
- 11 Jan 2004
- Messages
- 46,501
- Reaction score
- 3,792
- Country
Would like 7 x MK K2757 engraved.
Where is the best place to go?
Cheers.
Cheers.
Perhaps - but if they can't, you probably could?They can add paint?
I suspect it requires very little dexterity or skill - just paint (maybe even nail varnish etc.) over the area of the engraving and then wipe off the excess - and then clean up any paint left where it shouldn't be with wire wool or whatever once the paint has dried?Bit cack-handed for that.
What happened if someone plugged a dishwasher into a socket labelled "freezer"?Mine were common ones, such as dishwasher, boiler, freezer etc.
Mine doThey can add paint?
What about getting some things 3D printed that would go between the socket and the wall, and project above (or below) it with a small section bearing a legend, also part of the 3D printing. OK, it wouldn't be painted, but...?Would like 7 x MK K2757 engraved.
Cheers.
I was thinking that under the glaze, isn't the plastic a bit porous? Maybe a fine-line marker pen would do the job.I suspect it requires very little dexterity or skill - just paint (maybe even nail varnish etc.) over the area of the engraving and then wipe off the excess - and then clean up any paint left where it shouldn't be with wire wool or whatever once the paint has dried?
I've done that in my time, with fairly acceptable results.
I suspect you might get sent to prison for a long timeWhat happened if someone plugged a dishwasher into a socket labelled "freezer"?
Yes, maybe - although I'm not convinced that the urea-formaldehyde stuff is significantly porous at any depth.I was thinking that under the glaze, isn't the plastic a bit porous? Maybe a fine-line marker pen would do the job.
