Engraved Accessories
11 Jan 2004
Would like 7 x MK K2757 engraved.
Where is the best place to go?
Cheers.
A google search found a couple of possibilites.
I got some off Ebay af low cost, when they had been professionally engraved and were presumably left over from a job.
Mine were common ones, such as dishwasher, boiler, freezer etc.
Do you need non-standard ones?
I also use my labelmaker, but that's not so durable in a kitchen where there may be splashes and they are cleaned frequently..
Bit cack-handed for that.
I suspect it requires very little dexterity or skill - just paint (maybe even nail varnish etc.) over the area of the engraving and then wipe off the excess - and then clean up any paint left where it shouldn't be with wire wool or whatever once the paint has dried?
I've done that in my time, with fairly acceptable results.
Cheers.
What about getting some things 3D printed that would go between the socket and the wall, and project above (or below) it with a small section bearing a legend, also part of the 3D printing. OK, it wouldn't be painted, but...?
That way you could change the sockets but keep the labels if wanted, you could dispense with the labels without having to replace the sockets.
I was thinking that under the glaze, isn't the plastic a bit porous? Maybe a fine-line marker pen would do the job.
