Correct.Then there is nothing more I can say to you about the subject then
If you have opened your mind to that, then I suggest you get help.you have already closed your mind and convinced yourself that they do not exist on earth.,
I know what I saw and had I not seen it for myself then I would probably say the same as you are now.If you have opened your mind to that, then I suggest you get help.
Not many folk would have you down as a reliable witness.I know what I saw and had I not seen it for myself then I would probably say the same as you are now.
No, that's a shame isn't it.Not many folk would have you down as a reliable witness.
No.Do you think they exist?
Yes.This thread is about Aliens. Do you think they exist?
Not sure what you're referring to, but ok,.Probably more chance of finding intelligent life in Staffordshire
My Dad was a crane driver, 60 ton mobile, he worked hard.Yes, how else can you explain the Liebherr 11000 crane?
Crawler crane LR 11000 - Liebherr
The LR 11000 can cover a wide range of jobs with its boom versions. Port handling, industrial construction, infrastructure or wind power – the LR 11000www.liebherr.com
WOW!Possibly. We are a curious lot. There are dedicated nosey folk out there probing excitedly for the slightest glimmer. It's like a pin dropping would be a major revelation. So far - zilch.
It has to be a physical presence yes. Otherwise you are chasing spooks.
