Those extension leads, on a drum
To be fair 120W would be an absolutely whacking LED :) Bring your sunglasses
That was surely morqthana's point - wasn't it - namely that even a ridiculously large LED, running continuously, would not require the cable to be unwound? Even a few of those used simultaneously would probably be fine with a not-unwound cable.
[QUOTE="robinbanks, post: 5999706, member: 301902"
[/QUOTE]
The impression I get is that LEDs are about 1-2 times as efficient as flourescent tubes and flouresent tubes are normall around 60W, so it's "only" the equivilent of 2-4 flouresecent tubes.
If you think in terms of incandescents, the light output is usually 6-10 times that of an incandescent bulb of the same wattage. 120W worth of LED therefore should produce about the same amount of light as would 720 W - 1,200 W of incandescents - which would be an awful lot of light, at least in a domestic setting :-)
Many of the rooms in my house are (adequately) lighted with just 12 W or 15 W of LEDs.
When I'm rewinding cables I always run it through my hand, it's called Portable Appliance Testing and inspection
A cloth is better as you can clean the cable without getting your hands sh...dirty.
You're obviously a fan of trip hazards.
If, as if often the case, the load I'm using is less than the maximum stated for a 'fully wound' cable then, unless the manufacturer is lying, I see no reason to unwind it any more than I need to (hence avoiding unnecessary 'trip hazards').
I'm not a fan of trip hazards. I advocate sufficient socket-outlets so that extension leads aren't required.
and when working in area, where sockets are in the process of being added, how would you get a source of power, without using an extension?
I don't think that the 'wound up' extension reels on drums or in 'cassettes' are often used indoors because of 'insufficient socket outlets'. They are most commonly used outdoors and/or in situations in which there are no (live) sockets at all in the location in question.
My two, are used as a last resort, and normally outdoors, in wide open areas, and despite having three or four outdoor mounted sockets available to be used. Indoors, we have a range of short extensions available, should they be needed - despite having lots of sockets, there will always be occasions when there is not a socket where one is needed, and it would be ridiculous - to start chopping out the wall, to add a socket, to satisfy a few minutes exceptional need.
