Quite so ....What, even when the load doesn't exceed the rated maximum for a fully wound extension?
Not necessarily. They sometimes come with indications of the maximum safe loads when wound and when unwound
Yes. It's good practice always to fully unwind the lead.What, even when the load doesn't exceed the rated maximum for a fully wound extension?
It doesn't need to be anywhere close to its (not "it is") maximum capacity to need to be fully unwound. The coiled capacity is greatly reduced. And it can heat up very quickly. Don't expect me to promote irresponsibility.That is not always necessary. It only needs to be unwound fully, if the intention is to use it close to it's maximum current capacity, and for an extended amount of time.
You're obviously a fan of trip hazards.Yes. It's good practice always to fully unwind the lead.
Your being unnecessarily picky their.It doesn't need to be anywhere close to its (not "it is")
It is.The coiled capacity is greatly reduced.
whenever it is being used."It's good practice to always fully unwind the lead."
What size is the cable and what are you using it for and does any info on the reel give you a clue and does it have a thermal cut-out?OMG so do I unwind the lead or not...
I'm using mine to trip people up?What size is the cable and what are you using it for and does any info on the reel give you a clue and does it have a thermal cut-out?
Or a non-intermittent LED light drawing half an amp or less.In many cases where these extensions are used, drilling intermittently etc., there is absolutely no need to uncoil
Quite honestly we have given up with trying to understand some the self proffessed idiosycrasies you create.It doesn't need to be anywhere close to its (not "it is") maximum capacity to need to be fully unwound. The coiled capacity is greatly reduced. And it can heat up very quickly. Don't expect me to promote irresponsibility.
Everytime, unless you don't need toOMG so do I unwind the lead or not...
