Some people appear to have a deficiency in relation to one or both of those attributes.It is not irresponsible, it's common sense, with a bit of knowledge stirred in.
To be fair 120W would be an absolutely whacking LEDOr a non-intermittent LED light drawing half an amp or less.
That was surely morqthana's point - wasn't it - namely that even a ridiculously large LED, running continuously, would not require the cable to be unwound? Even a few of those used simultaneously would probably be fine with a not-unwound cable.To be fair 120W would be an absolutely whacking LEDBring your sunglasses
This thread is turning into an unwind-up
In which case it needs be wound down.This thread is turning into an unwind-up
If you think in terms of incandescents, the light output is usually 6-10 times that of an incandescent bulb of the same wattage. 120W worth of LED therefore should produce about the same amount of light as would 720 W - 1,200 W of incandescents - which would be an awful lot of light, at least in a domestic settingThe impression I get is that LEDs are about 1-2 times as efficient as flourescent tubes and flouresent tubes are normall around 60W, so it's "only" the equivilent of 2-4 flouresecent tubes.To be fair 120W would be an absolutely whacking LED![]()
A cloth is better as you can clean the cable without getting your hands sh...dirty.When I'm rewinding cables I always run it through my hand, it's called Portable Appliance Testing and inspection
Yes I agree but that bitA cloth is better as you can clean the cable without getting your hands sh...dirty.
gets missed.called Portable Appliance Testing and inspection
I'm not a fan of trip hazards. I advocate sufficient socket-outlets so that extension leads aren't required.You're obviously a fan of trip hazards.
If, as if often the case, the load I'm using is less than the maximum stated for a 'fully wound' cable then, unless the manufacturer is lying, I see no reason to unwind it any more than I need to (hence avoiding unnecessary 'trip hazards').
It's actually called in-service inspection and testing of electrical equipment.When I'm rewinding cables I always run it through my hand, it's called Portable Appliance Testing and inspection
I don't think that the 'wound up' extension reels on drums or in 'cassettes' are often used indoors because of 'insufficient socket outlets'. They are most commonly used outdoors and/or in situations in which there are no (live) sockets at all in the location in question.I'm not a fan of trip hazards. I advocate sufficient socket-outlets so that extension leads aren't required.
