EICR and fuse box
Get it upgraded by an electrician and future proofed. RCBO's and upgrade the mains tails etc.
Just out of curiosity, what is the condition of the wiring?
And when the electrician recommended you to change the board did he also provide an EICR?
But will the new one last as long as that one has :unsure:
You'll be lucky; that's what they did when that one was fitted.
Well it seems like ‘future-proof’ has an expiry date now.
Do you think we are expecting any more big upgrades now? For eg going from MCBs to RCBO's is pretty much the last major step. Can’t see much else changing after this for quite a time.
I suspect at some point AFDD manufactuers will lobby the IET for their products to be required more widely.
Oh yes indeed. Mandatory AFDDs are coming this way and fast
I say 2 fingers up to the muppets in the IET
Hi
I had EICR with a property I let 5 years ago, few electricians asked to replace the fuse box (pic attached). I Managed to find an electrician who passed it.
Is it still passable today?
The whole of that question by the way it is asked leads me to shudder. Maybe my interpretation of you asking a few electricians and managing to find one willing to pass it.
I suppose I am inclined to ask you you how deep was the barrel you were scraping the bottom of?
With only 4 circuits, it's not going to cost a fortune to upgrade, unless of course the whole lot is shot
2x32 and 2x6 makes me wonder how well appointed this property is .. one ring final, one cooker and 2 lighting circuits is hardly palatial :unsure:
6 circuits 3 x 32(30), 1 x 16 (15) and 2 x 6 (5) would have accounted for a very common set up with the old Wylex 604 allowing for 1 cooker and 2 rings, one immersion heater, two lighting circuits, simple . For those too young to remember the figures in brackets would be for rewireable fusewire then the early MCBs - wylex MCBs were push button not toggleswitched type
The problem with the old Wylex:-
1) Only rated 60 amps Wylex 60 amp.jpg 2) Most were damaged over 30 amp fuse used.Wylex burnt contacts.jpg 3) Wylex heavy duty.jpg Those with the ability to take a larger fuse, it was only on the first fuse carrier. There was nothing to stop an ELCB-v from being fitted, ELCB-v.jpg but the test gear Clare ELCB tester3.jpg is long gone. But nothing to stop the ELCB-v from being replaced with an ELCB-c, but when that was done, it was often the 100 mA version. I have seen where the 100 mA has been swapped to 30 mA, and also seen the problem with it tripping all the time.
I remember having to call into the county council housing department, and while there hearing the calls for faults. Toilet leaking water out of the overflow for example, and thinking I would have simply adjusted the ball cock, and would have not dreamed of calling out a plumber. And I know in my mother's house, there was no way she could get her wheelchair under the stairs to reset a RCD, so a simply RCD trip was a call-out job. She did not call anyone out, it was automatic with the telecare, they would call me, and tell me the power had failed.
I can see why a Landlord would not want to be called out to reset a RCD, however, also saw what my mother did, when she found an extension lead with a flickering neon, with macular degeneration plus Alzheimer's disease, she did what in some ways seems sensible, she put the extension in a bucket of water, a wake-up call for me, and new consumer unit, in fact a re-wire was then done ASAP. But not easy, as could not really have it done with her in the house, and back then looking at £600 a week for accommodation for someone with Alzheimer's, and she had not been sectioned, so not permitted to lock her in. Lucky for an unrelated problem, the social services put her in a home for a time, so it was a mad dash to find someone who could rewire the house while she was away.
We all tend to look at our own homes, and forget some homes have children, and some have old people, and these may be visitors rather than the tenants, and with carers, they are at work, so HSE rules also kick in. Also seen this with the working from home, one is then at work, and all the HSE rules apply.
As to what insurance companies will allow, I don't know? But there are so many things which I can do at home, but not allowed to do when volunteering at a local heritage railway.
Before mother died, I looked at renting out her house to pay in part for her care, and putting her in a home, not what I wanted to do, but needed to be ready, and the letting agent came in, and it was a massive list of what needed to be done, seems the domino hob was not permitted, needed 4 heat areas, so when she died, I took easy way out and sold the house.
And I have seen it here, where landlords are simply selling up, too many hoops to jump through, seems there are caravan parks popping up everywhere, to fill the gap, and I do look at old two up and two down houses, and think even if not to spec, it would be better than a caravan!
But we don't make the rules, so we either pay up and get it to comply, or sell up, no real option to do anything else.
