Is there a way to remove screw blanks from light switch?
24 Feb 2007
Hi guys, an age old problem of mine. It’s over way to remove the screw blanks without destroying them?
Insulation tape or blue tack sometimes works but not every time
Cheers Pete, I’ll give those a try
Yea that’s been my goto but it tends to kill the edges. Bluetac seems like the way to go.
If that is a click scolmore switch, give scolmore a ring and they will send you new covers for free. I hoook them out with the tip of a corkscrew and then fit new covers.
Good sticky gaffer tape would surely work.
PLAN B - stop being so precious and accept visible screwheads. Buy some on AliExpress in vibrant colours and make a feature of them.
There should be some spares inside the switch plate, if the person doing second fix has any consideration.
Take them out and throw them in the bin - cheap tacky rubbish
I think they make the accessories look cheap and nasty.
I first saw them in the 80s when they were supplied with cheap nasty imported stuff and Clipsal branded stuff.
Now they're back...
Get rid and dress the screws nicely.
Or just not bother with that level of obsessiveness
But if you must then buy Torx or hex head screws - far fewer dressing problems.
If nothing else works, a little silicone on a nail head and leave overnight.
Then pull.
Although a good go with gaffa tape works 99% of the times.
My preference is Torx screws without a doubt, especially if you want to keep a reliable connection for your screwdriver.
The sort of torque applied to screws holding on switches and sockets isn't going to bother any screwdriver/head design.
I just suggested Torx or hex head for the anally retentive, to make it easier for them to get all the heads lined up than it would be with slotted ones.
