Yeah, when I used to go fishing years ago, that’s why I asked. What I did then was squat and fall back against a tree trunk but even then, you had to make sure you didn’t shìt straight into your pants. Mind you, I was usually wearing wellington’s and that made it harder to pull your trousers right down…Have you never done a rough poo, out in the wilds?
I once did a poo in the sea (water skiing enama) and it's one of the best poos ever.Yeah, when I used to go fishing years ago, that’s why I asked. What I did then was squat and fall back against a tree trunk but even then, you had to make sure you didn’t shìt straight into your pants. Mind you, I was usually wearing wellington’s and that made it harder to pull your trousers right down…
It's the natural way, and not just Muslims, probably most humans still. Better for your bowels and anal passage, less strain, less damage ...Crouch and have a shyte I think (don't go mental people) I think Muslims do it![]()
That must have looked like an octopus making his escape!I once did a poo in the sea (water skiing enama) and it's one of the best poos ever.
It floats instantly and then tries to follow you.That must have looked like an octopus making his escape!
Find another toilet i would![]()
Its a manual bidet....
You should be able to squat and sh*t without propping yourself against the wall...
Otherwise it's an 'old man test' failure![]()
When you have done your job, a hand comes up from the hole and cleans the exit site!!!!
Notchy would know..Does it do 'extras'?![]()
