Hawd the bus!! I never said the EV fitter didn't fix the issues. He double checked my earth bonding and did indeed tighten the screws in the Henley block.
My greivance is purely with the initial meter swap insatall.
It can sometimes be viewed as much with a quick glance by the untrained eye until a slightly more critical observation is made.
Things are not always as obvious as first seen.
It can sometimes be viewed as much with a quick glance by the untrained eye until a slightly more critical observation is made. ... Things are not always as obvious as first seen.
Fair enough, but I imagine you must be thinking of a situation in which what we have been told is not actually true, are you?
If what we've been told IS true, then there surely can be no doubt about a 'metal pipe emerging out of the ground and entering the property', can there?
