Concealed joints again!
That rather depends upon whether it's one containing acetic acid, doesn't it? There are one designed for 'electrical use' around.
Been there, seen that done to weatherproof RF connectors, wouldn't do it again even though the manufacturers picked up the tab for 2 riggers.
However, morq's point was obviously that the regs seem to be happy with any 'compound' :-)
OTOH, if it's just twin & earth under the floor/in a ceiling, and you're looking for a compliant solution, just bung in Wagos or Ideals etc, rather than faff about filling a screw terminal JB with Play-Doh or whatever.
Sure, in practice that's what one would do, if one were bothered about 'compliance'.
However, as I'm sure you understand, the reason I raised the issue was that I suddenly realised (after years of not thinking about this) that the regs really do seem to allow non-accessible screwed joints if one squirts some (unspecified) 'compound' into/over them!
I wouldn't use play-doh... it's conductive
Oh yes rodents love Play-Doh and coincidently so do small children
I imagine that's not quite a 'co-incidence', since I would presume that it's been deliberately formulated to be safe for small children to eat - particularly given that they will have a go at eating most things *(like soil!),even if they don't taste very nice :-)
Sticking with potted joints, as long as the potting compound (at least partially) surrounds the screw heads - then the screws cannot work loose. That only leaves creep - and I remain "unconvinced" thats a problem given the number of screwed joints in a typical house installation (manynof which get no routine inspections.)
Yes, but only IF the (unspecified in regs) 'compound' more-or-less 'sets' (which proper potting compound would) - many of the other 'compounds' which have been mentioned would do little, if anything to stop a screw becoming loose. I suppose it comes down to whether one applies common sense or whether one goes literally by 'what the reg actually says'!
Indeed - and I'm actually not really convinced' about either. In fact, there's probably a fair degree of overlap, since I would have thought that 'creep' (if it happens significantly) is one of the few likely causes of 'screws loosening' in non-accessible JBs, which are usually subjected to minimal stress or mechanical disturbance (leaving the only other thing I can think of being 'thermal cycling', which shouldn't really happen with a well-made joint).
A properly made joint, especially in the usual brown Bakelite type joint box, is less likely to thermal cycle, than the wire itself. A properly made joint, has the wires overlapping, under the screws, making the resistance lower than the wires.
Exactly. That's why I wrote (and you quoted):
.... 'thermal cycling', which shouldn't really happen with a well-made joint).
