New Flange Plunger Out Of Shape - Toilet Waste Pipe Partially Blocked
17 Feb 2006
Manchester
Hello guys the house im private renting in has toilet draining problems, it has been fine for over a year so far. I bought a new £10 flange plunger from Amazon, its useless as its out of shape and it wont get a seal. It wont reshape even when i bathe it in warm water.
I have severe IBS and i use baby wipes all the time. The baby wipes dont seem to be the problem and the manhole in my back garden seems fine and does not flood.
Sometimes i have chronic diarrhea and sometimes i do very large poohs. Quite often it takes a few attempts to clear the poohs when flushing. Recently it has started leaving poohs at the bottom of the bowl. It does flush and drain slowly, it just struggles to remove my poohs. I get the impression the bend is partially blocked.
am i on the right path regarding this type of plunger? See pics of the manhole and rubber plunger in the warm water its like a rugby ball.
Item on Amazon https://www.amazon.co.uk/dp/B07BD5JV2R?ref=ppx_yo2ov_dt_b_fed_asin_title
I'll have ago at this.
Good grief?
You shouldn't flush baby wipes to start with.
Only use flushable wipes. Come on. You know this...
And if I'm honest you shouldn't be using them.
Get and wash yourself with soap and water like over half the planet has done for 1000s of years.
You can also start flushing at different stages and with an empty bowl flush along the way well before you have finished.
I have seen toilets with drain problems so you need to get a camera down and have a look, and If you look on YouTube there are companies that have a following with the fancy toys. You need to go watch and learn and maybe get a 6 monthly cleaning visit.
Unfortunately some drains although fine aren't great.
You can't just drop things off plus paper and expect it to go.
That's all I want to say on the mater
If you must use wipes, put them in the Bin. They cause utter havoc in the drainage system, cost a Fortune to keep removing and when they do eventually find their way through the treatment works, are screened out on arrival and put in a Bin. Which goes straight to landfill/Incineration.
Cut the middle man out, and help save the rest of us a few £.
Yes, there is a Pump under that lot.
Good grief?
Good afternoon and thanks for your reply.
From a Diy perspective surely getting a camera is not quite needed at this stage. It looks like the restriction is close to toilet itself so i thought a good plunger might help. Running water into the toilet flows to the manhole which would suggest the block is close to the bend.
I dont work and dont want to throw money away unless i have too. Can anything be accessed to check it manually?
thanks for the warning my friend but i need to find a diy way to clear my toilet waste pipe or u bend ;)
Do you have a dual flush cistern. If so after use hold handle/button down until cistern empties after each use.
As a first step pour a bottle of bleach down the pan and leave. overnight that might clear a partial blockage.
Go to Screwfix/Toolstation/wherever, get a decent Plunger. A Drain Rod with 4" Plunger on the end has never failed me yet to clear a blocked WC Pan, £30 on a set of Rods will still be cheaper than getting someone in and you've got them for the next time you drop a baby's arm off.
Many thanks for your reply. What about this set from Toolstation £32 ?
So do you recommend doing this from the actual toilet and not the manhole?
Hi mate thanks for your reply. The cistern empties when i flush, there seems to be a problem with it flushing and it often needs a sharp fast push for it to work.
I have poured the 2 bottles of bleach i have and if this does not work i might need to buy a rod and plunger as suggested. ;)
