Help Replacing Light Fitting? UK
12 Jan 2026
I'm trying to swap a regular single pendant bulb light fitting for a 4 bulb ceiling light, something like this - https://www.diy.com/departments/flux-steel-gold-effect-4-lamp-ceiling-light/5014838946299_BQ.prd
The wiring diagram with the new fixture shows I need the usual live, neutral and earth. I am aware of the FAQ for replacing a rosette, however when removing the fitting, instead of a rosette I see the below, and I'm not quite sure to proceed.
I'm guessing what I'm supposed to do is remove all the existing fitting and the terminal block. For the live and neutral, I'm assuming for the new light I want the two lengths that come out of the ceiling and enter the terminal block, and that the lengths coming out of the block and travelling down the white sleeve will just detach and become scrap wire.
For the Earth wire, I assume I just take the line attached to the serpent holder block and use that. As this is quite short and appears to be connected to an extender block anyway, I was going to remove the existing length and put in a longer piece of wire to make hooking the new light up easier.
Can anyone confirm if this approach is correct? Thanks!
Hopefully there will be slack cable in the ceiling and you won't need to extend the wires. Remove the screws and pull the rose dowm so that you can see what length you have to work with.
I think you will have some slack in the wires in the new fitting, can you post a pic of that too.
Did you get any replies on Redit?
Your link is for B&Q app.
Sometimes, depending upon the fitting, it is possible just to remove the existing ceiling rose cover, perhaps slacken/temporarily remove the fixing screws and install the base of your new lamp. The connections for the old pendant flex being removed and used for connecting wires for N & L of your new lamp and perhaps an E link from the rose to the new fitting.
It is not usually necessary to refit the old rose cover before the new base is fitted.
That way makes it nice and easy to change and also has the advantage of making the old cover and pendant back and take your new fitting with you if you move home.
Oviously, whenever undertaking such electrical work then follow robust good isolation procedures and if you are not totally competant to do the job then get a pro to do it.
The existing rose only has L, N and E connected, nothing to go wrong there. Those Wagos and choc block are where it gets interesting. They shouldn‘t just be stuffed into the ceiling like that but if the new light only has a mounting bracket and cover it doesn’t really make a difference whether they’re against the ceiling or just inside a hole in the ceiling. The easiest way of wiring this would be connecting the short bits of wire to the new light.
Unless the new lights wires reach the connectors
