This is the problem, I have a loop impedance tester, so I just use that.
On the odd time I don't have one, I have to look around me, and decide what reference point is valid, no good using a radiator tap with plastic pipes for example. And found with mother's house it simply had no earth to whole house. How I don't know, as a lad I made an error line to earth and ruptured a 13 amp fuse, so it did have an earth, but hunting around the house, all bonded together, but no earth, only thing I could find was an earth stake from the old party line telephone.
Long story short assumed earth had been from water pipes, and new plastic water main resulted in no earth, house wired 1954. So got the DNO to give me a TN-C-S supply.
So without a loop impedance tester, or earth tester
View attachment 405481View attachment 405483how does one start? Until found no earth in mother's house never even considered it would not be at the consumer unit. Old fuse box had already been changed to a consumer unit, but I could find no sign of either a DNO fuse, or an earth rod.
I can think of methods, like using an old tungsten bulb, but there would be some danger, and I am not willing to detail how I would do it for anyone to read, it could be a pre-1966 installation when earth was not always taken to the lights. But until
@RK_London confirms that other outlets do not show a floating earth, then all tests with a multi-meter are invalid.
