Which Radiator Make and TRV / Lockshield?
30 Oct 2003
Worcestershire
Question of two parts:
With the on-going saga of cold / warm rads that a flush didn't fix (probably due to microbore and manifolds being blocked), it was suggested that at least some rads would benefit by being changed. This is a job that I can do myself, I feel.
The bathroom and en-suite will not be changed immediately as they are going to be refitted, so I need only seven new rads.
I am looking at Kartell and Stelrad. Are these the better end of the market? or are the likes of Screwfix any good?
Whilst I am doing this I might as well change the TRV and lockshield on each as we have a bit of a jumble now, and one seems to be faulty. The existing lockshields all have a drain spigot (even those upstairs) so I assume that only one on the ground floor would actually need a drain cock?
Is there a recommended manufacturer for the TRV / lockshield?
Consider Henrad from Wickes.
Part of Stelrad group, apparently and thus still made in UK.
TRVs/lockshields Pegler Terrier (or Bulldog rebranded ones) seem OK from my DIY experience of them, and you can get them with a drain-off if you want that feature.
The pro experts will have their own preferences / recommendations, I'm sure.
You will be lucky, I have tried a few times to start a discussion about what TRV heads do what with comments like "Life is too short." as the reply.
I was not impressed with Energenie, even the cheapest TRV heads have
error codes to show range too wide and range too small, the eQ-3 head at £15 has this, so one would hope more expensive models would also have it. Some makes due to length can be rather vulnerable to damage 1771268629784.png1771268629784.png and some are not able to be manually set, one is forced to use an app. There are kits to match them with different bases, 1771268871717.pngsome with more options as to others, but the 30 mm base ring seems to be what most use. I now have Drayton Wiser, which has been working well, but I have only used 4 makes, I at £15 a head would not consider using a manual head, but as to if worth paying more for non-linked heads not so sure. The linked Wiser head means there is no need for any wall thermostats, but having to either bend down or use an app, is not what we all want, the likes of Kasa and Wiser you can combine a wall thermostat or sensor with the TRV head. But size of ones home and design can change if they really help, my last house open plan, I only had TRVs upstairs, one wall thermostat downstairs was enough.
And also heat loss, I see with the graph,
my heat loss is low, and not having the heating running overnight is not really a problem. But my first house had same heat loss in a couple of hours, so it needed the thermostat to be programmable.
Rads are much of a muchness, but new radiators won't fix pipework issues
Indeed not, but I am thinking of having a look at the pipes myself, so whist drained down I can swap a few over. I think the thinking was that if the rads are corroded, then it would remove the possibility of chunks of corroded material coming away and blocking again.
The lowest point, of every 'pipe drop', needs to be fitted with at least one drain valve, if you want to make draining down easy in the future.
Ah yes, good point. Strange that the upstairs rads have them!
I have 3-off Henrads that were replacements in the utility, bathroom and downstairs loo. Two have paint flaking at the bottom and one is quite rusty on the surface already. It may be the dampp atmosphere, but the loo is not overly damp I would say.
