Bizarre outside bottle gully problem
22 Sep 2022
Kitchen waste to bottle gully, then off to foul / rainwater waste (or whatever its called). It's been in service since the house was built 24 years ago. Over xmas I noticed the water wasn't draining from the sink when the washing machine was emptying (it had done for many years prior), so thought it was blocked. I removed the Dip Tube, cleaned everything up, but found no issue. With no Dip Tube, I threw 5 x14 litres buckets of water down the sink, it cleared with no issue. I put the dip tube back, and it blocks after one bucket. Nothing has change for 20 odd year, so can anyone give me a clue about what the issue may be?
At a guess, either a load of Detritus in the bottom of the Pot, but if you've cleaned that out, then I'd suggest there is a blockage downstream of the Gully.
Tipping water down with the Dip Tube removed, would allow the water to fill the outgoing pipework and displace the same volume of air back out. Putting the Dip Tube in, and that air is then trapped in the pipework, preventing the water from displacing it.
As HJ says, remove the trap sleeve and get the Marigolds on.
THe inside of the gully has been cleaned to the point you could eat your dinner out of it. The outgoing pipework runs for around 3 metres before it joins the main pipework into the road. Rodding suggests it is clear ???
In the road, there are two circular covers every so often which I believe are they mains sewerage, then at the edges are the metal gullies where we (my neighbours and myself) believe the kitchen gullies empty into.
Is that public road, or private?
My washing machine STINKS when it's draining. I've cleaned the front thingy, sucked and blown the hell out of all the pipes with my wet vac, cleaned the rubber gasket thoroughly and I've checked the sink trap and exit pipes. I've also run the wash cycle with bleach (okay, I was getting desperate). The sink and washing machine both drain well, so what am I missing here?
Maybe it's full of ectoplasm.
Public Road. The distance between my gully and the property boundary is around 5 metres , I've managed to get a thin rod that far downstream and can find no resistance. From then it is around 3 meters to one of the first round manhole covers which access the sewage. (18 houses in one small cul-de-sac).
You cannot really check that, maybe ask if your drainage company can investigate.
I did, and nearly had an heart attack when they said what it would cost. They advised to do all I can to eliminate any blockage on (or under) my property first, then call them. Hence why I've tried to measure the distance and direction. From my kitchen sink to the edge of my property by the main sewer pipes is 2.5 m, but I know the pipe goes of at an angle, so measuring that route is around 5 metres max ( unless the pipe goes around in circles). I got bored this morning, so a few of us in the street lined up 18 full 14l buckets, put the hose down there flat out (my water is a set rate thankfully), and chucked one bucket after another down there, and it took the lot without any issues, thats around 300 litres. Put the dip tube back and it struggles to take one 14l bucket before it gurgled like buggery. It could only have filled up a small section of pipe and the gully. For now, the dip tube is in the garden and its staying there until either a rat sticks its head up the plug hole or the smell (when it comes) is a tad off putting when cooking.
Clean out the overflow on the kitchen sink! ;)
Andy
