Shaver and toothbrush sockets
26 Aug 2007
Lancashire
Hello!
Bathroom cabinets with shaver and toothbrush sockets are rediculously expensive and also i am struggling to find one that will fit the space!
Im now looking at fitting a socket into and "normal" cabinet. However, most wont fit the standard 150mm x 90mm x 55mm box.
Are there smaller versions i could use?
Ideas and options requested.
Thanks in advance.
Crakkers
No. You are not allowed any socket in a bathroom (unless you have a very big room). socket located more than 2.5metres from the bath shower.
The safety socket is needed for a reason.
Anyway, I guess you are charging up a toothbrush or shaver? You don't even need to do that in the bathroom. my toothbrush keeps its charge for 3 weeks +
I just plug it in the bedroom.
Ridiculously expensive?
I don't find the need for a shaver socket
and I only have 5 teeth left. The sockets were from a time when we did not have battery powered electric shavers, and the transformer is turned on by inserting the plug, and designed in the main for intermittent use, to leave it turned on for an extended time, i.e. leaving something plugged in, will often cause overheating.
I have not found a mains powered tooth brush, maybe there are some made? But in the main battery powered, and whole idea of battery powered is you don't need to charge them in the bathroom.
I don't have the latest regulations can't justify the £125 price tag, but looking at my old copy it seems SELV or PELV is permitted, so fitting a USB outlet does seem to satisfy the regulations. Maybe someone can confirm this, as I am out of date, but that does seem to be the way to charge tooth brushes in the bathroom, they are designed for continuous use. In the old book it had to comply with BS EN 61558-2-5 maybe that has now changed?
As to a cabinet, not sure on the rules, I suppose if the supply is turned off when the door is opened it may be OK, is in side a cabinet considered as being in the bathroom, but I think the BS EN 61558-2-5 still holds for a cabinet?
Bathroom cabinets haver small sockets, that is what I am trying to source.
Yes they do, but - inside the mirror enclosure- there is a safety isolating transformer which is mandatory in most UK bathrooms.
You can’t have the socket without the special transformer, sorry.
Watch this
Bathroom cabinets with shaver and toothbrush sockets are rediculously expensive and also i am struggling to find one that will fit the space! .... Im now looking at fitting a socket into and "normal" cabinet. However, most wont fit the standard 150mm x 90mm x 55mm box.
Any of the available 'shaver sockets' (with isolating transformer, as required, unless it is 'miles' from a bath/shower) would fit a 'box' of that size, wouldn't they?
Hi. I meant the cabinets with sockets are expensive, not the sockets.
What do you call expensive in relation to these mirrored bathroom cabinets with shaver point in?
BTW the price on them has increased considerably since the Iran war started (like most other things).
If it has LED illuminated mirrors with demister and internal shaver socket, this is a luxury item for in a bathroom and hence they fleece us even more.
I purchased this one before Xmas for 179, it's now 199.
Still many times more than a simple mirrored cabinet would cost, but it is nice.
