Like a lot of things, plug in solar is here and for all the bleating consumers will just vote with their wallets and it will become defacto regardless of what any trade, supposed safety organisation says.
Yes very well put.
Bernard, thanks, that piece was a very interesting article and brought up some good "food for thought" for us to digest and consider.
What was wrong with my #79 post? At 3:12 on the video he starts to address the islanding problem. At 4:00 in he says inverters will stop when mains is removed, with a compliant inverter, but as, yet we don't have any compliant inverter. The standard only applies to installed inverters, and plug in is not installed.
At 5:00 he hits the real problem, people will break the rules, but since as, yet we have no rules, that is a little pointless.
At 7:00 he tests using two panels with a load, but the worry is not two solar panels, it is where we have 10 solar panels.
7:46 he tests will the RCD work, this test seems valid, and yes the RCD will work.
at 9:34 is the interesting one, 0.5s is very different to 40 mS, the main idea is we don't want 100s of inverters disconnecting when we have a small dip in the voltage due to load on the grid, which could cause a domino effect and the grid failing as 100s or 1000s of inverters all turn off together. So there needs to be a delay.
10:15 he looks at bidirectional. 12:20 he shows to oscilloscope display, where he claims the device trips that fast with a real fault it does not cause a problem, but the real question is if someone is exporting when they test the RCBO with the test button, so in real terms it tells us nothing.
12:45 he does address the problem with overload of a circuit.
14:50 he points out we can buy all sorts which can cause problems. 15:15 he talks about people causing risk without solar, and lack of EICR. And 15:43 he starts on about the wind risk with solar panels or any other product be is a stack of corrugated sheets or a trampoline.
At 17:10 it becomes an advert. By 17:51 he is talking about 2.4 kW.
18:28 he starts advertising again, and talking about battery storage.
By 20:25 he is saying how 2.4 kW can be drawn direct, by 21:25 he is talking about what can be supplied with a proviso that this may change i.e. still in advertisement mode.
He ends with the problem of raising voltages tripping EV chargers.
As I've just written, if it cannot be plugged into any existing BS1363 socket, then I really don't think it would qualify as 'plug-in solar' in the sense that most people are thinking of that term.
I do see your point, but governments love a get out clause.
As it stands, nobody knows. And while we are debating what is allowed, solar panels are being installed.
