BoschSeries 2 fridge door left open - no longer gets cold enough
The dish round the back is adequate for normal use, but may overflow if you have a lot of ice. I like to see it and sponge it out ( it may be very dirty)
When empty, the FF will be quite light. Clean the floor and spray it with furniture polish to help it slide.
Pack your expensive meat and fish in the middle of the box, surrounded by frozen peas, chips and pizzas, which you can eat later, or throw away if necessary at low cost. A large, double cardboard box wrapped in a duvet offers quite good insulation.
We have the electric cool box which hopefully will be better. I have a 2 wheel sack trolley I can get it out with when empty.
Ok, I can't see any drip tray at the back and I can't pull off the panel to see if ice is on the evaporator but leaving a fan blowing towards the inside should do it.
The drip tray is usually on top of the motor assembly where waste heat will help the water to evaporate.
It's been defrosting overnight for about 11.5 hours with a fan pointing inside the freezer. Both doors open. I have just turned it back on and now hoping that has fixed it.
Ok, the freezer is at -18 which is normal and the empty fridge got to 4 degrees. However, an hour or so later putting a few food items in it went up to 12. 5 mins later it is at 10. There would be def no ice inside now after that long a defrost with fan. his is so frustrating!!!
Monitor it for longer. The thermostat will vary over it's operating range. What have you got it set to?
I have it set to the coldest setting. I read it again and got a reading of 5. Some time later and it was back at 10. I was really hopeful when it reached 4 degrees on first turning on again but it seems to swing rapidly. Perhaps air temp is not the best way of monitoring ?
Did you leave it open until it stopped dripping?
If you turn it back on while the ducts are still blocked you have wasted your time. You can't see inside the ducts and there is no airflow through them when they are blocked.
The food you put in the fridge will take time to get down to temperature.
I didn't see any dripping and none of the towels were wet when I pulled them out. It's can't be ice as it was left running with a fan overnight. What doesn't make sense is it was running at 4 degrees not long after switching on but now back at 12 degrees with the door closed a couple of hours, and yet the freezer remains unaffected, which means it can't have damaged any internal electric, and if after a few hours it hasn;t stabilised a full 24-48 hr defrost should do it
I use my Karcher OC3 portable washer with some warm water in to defrost my freezers. I just place a shallow baking tray under the drain-off to catch the thawed ice. Takes less than 15 minutes. I dry them off with Mrs Motties hairdryer. I remove the drawers with the frozen food in them, stack them outside and just just chuck a few towels over them to keep them cool.
It's a frost free freezer but again, after leaving the fridge to recover for 6 hours the temp at best is 9 degrees. Gutted! I can't see ice stiil on the element after 11.5 hours defrost in Summer with a fan blowing into it. And the fact that it hasn't made an iota of difference to the temp is astonishing. I don't even know how to take the panel off to see the element.
OK, but is that something I could do or would have to call an engineer out?
You need to establish which is the correct thermostat for your fridge. The spares sites software doesn't seem to be able to confirm it from your model number. there seems to be at least 2 different types so you will need to contact them with your model details before ordering. It's usually a simple part to replace especially when ther are vidos to show how it's done.
there is a vid here showing how to test before you decide to purchase.
And you should be able to find a supplier here if you establish that is the problem
Ok, thanks for that and simple enough. My cool dial just says Cold and colder with a graphic thickening line to indicate (clockwise colder) having said that I have checked the temp on coldest and it's getting as low as 5 degrees and fluctuating to 9 after opening. To me this shows the thermostat is working but the airflow is probably still inhibited somewhat.
