32A Commando plug to BS1363 socket
25 Oct 2010
I have a 32 amp CEE "commando" socket outside the house that I use for charging an EV. Sometimes it would be useful to use it for plug-in gardening devices and also a trickle charger for a motorbike.
I can't seem to find a fly lead adaptor which has a 32 amp commando plug (male) to 13 amp BS1363 / Type G socket (female).
I can find fly leads for 16 amp commando plug to 13 amp BS1363 socket but the 16 amp connector has a smaller diameter than the 32 amp one. I could get a 32 amp to 16 amp fly lead and use that as well but it seems clumsy and I'd would be preferable have just one fly lead.
Any ideas why this type of fly lead doesn't seem to be for sale anywhere? Thanks!
Ok, just found one on ebay. Don't know why I couldn't find it before. Thanks for your help!
Be aware that trailing sockets are normally only rated for 13A total.
For this reason, personally if making up such a lead I would use either a single gang trailing socket, or a fused 4 gang.
Be aware that trailing sockets are normally only rated for 13A total. For this reason, personally if making up such a lead I would use either a single gang trailing socket, or a fused 4 gang.
Good advice. However, being pragmatic, since 2-output 13A adapters without fuses are allowed, a 2-gang trailing lead would be 'no worse' than that.
What does that mean you've lost me.?
It means that adaptors like this one, without a fuse, are allowed so long as they have no more than two 'outlets' (with three or more outlets, a fuse is required), so that two 13A plugs (each with a 13A fuse) could be plugged into one actual 'socket', theoretically meaning that a total load of up to 26A could be being drawn from the one socket. Exactly the same would be true if one used a 2-outlet trailing socket (without fuse) in the OP's situation -so, if the situation with the adapter is 'allowed', then the OP using a 2-outlet trailing socket would not, electrically, be materially different.
Not sure if allowed, although likely the route I would take, I know it needs an isolator, so socket can't be made live unless there is a plug in the socket, but can't see me losing any sleep if it did not fully comply.
OK, we have to stand back and ask, are we worried about the regulations?
In the main, in a garage, non-domestic, we can have 32 amp CEE "commando" sockets which can be used to charge an EV. But once we move outside, then we have to look at the equal potential zone. And we have a whole list of problems we need to overcome.
The main problem is the TN-C-S supply, but this is not easy, so in the main, outdoor equipment is class II, so although we supply an earth to the outlet, in the main that earth is not used.
We could go for a TT arrangement, and for all we know, the whole home could be TT, so the throw up reasons why it can't be done, could be wrong.
I have a TN-C-S supply, and I have a 13 amp socket on my shed, which my son will use to charge his car, the chance of a loss of PEN when my son visits, must be very slim. But my son and I are aware of the danger, and we choose to ignore it.
But to tell a stranger to ignore it, is rather different.
Well, in this context I'm certainly not particularly 'worried' about anything!
However,as I said, I was merely making the pragmatic point that if 'we' are (electrically) happy with an unfused 2-outlet adaptor, then there's no reason why we should not be equally (electrically) happy with an (unfused) 2-outlet trailing socket, is there? Either of those approaches is BS1363-compliant, hence acceptable to BS7671 - so what could there be to 'worry' about?
