For what it's worth, it certainly does seem to me that 'a big switch' should qualify as an 'item of switchgear'How can anybody not accept that except by refusing to accept the rules of English grammar?
Yes that is one solution I passed by a DNO tails connection chappy and his reply/opinion he robustly and perhaps pedantically he rotorted that such switches have terminals actually marked as "L" and/or "N" etc therefore could not be used for other purposes - obviously my thoughts were, in essence, a 4 pole isolator could be considered the equivalent of two 2 pole isolators interlinked thereby one switching the normal domestic mains and the other switching the off peak mains and thereby all combined achieving full isolation of both of those single phase supplies using one switch action - I was disappointed with his conclusion - I thought I had bright idea until he countered it.
That depends upon what you mean by 'can'. In terms of the literal meaning of the world, it obviously 'would be possible' to install a plastic CU, anywhere (in any sort of property).As far as I recall, you can still use plastic consumer units in a domestic property. ... As long as they are not in the exit route including under the stairs.
And even the government guidance doesn't actually reference the latest edition of BS7671............since it doesn't relate to anything in BS7671 (compliance with which is not 'mandatory', anyway!)
On the left of the head appears to have enough space.Anyway, back to my original post. This is what I have. Is there room to fit an isolator there?
It's all a bit tight - how much space is there to the left of the meter/cutout?Anyway, back to my original post. This is what I have. Is there room to fit an isolator there?
