I assume this would be an easier location for quick accessAnyway, back to my original post. This is what I have. Is there room to fit an isolator there?
On the left of the head appears to have enough space.
If not screw another board to it that it will fit on.
It's all a bit tight - how much space is there to the left of the meter/cutout?
However, there nothing stopping you adding an additional board and putting the isolator on that. Indeed it seems that some 'supplier purists' ('pedants' ?) say that you shouldn't have an item of 'your equipment' mounted on 'their board'!
I see nothing that demands 'a board'. Indeed, I imagine that if the perceived issue relates to 'fire', most walls are probably going to be much less 'combustible' than most 'boards'!Thanks. There is enough room to the left of the head - do they have to be mounted on a board (if so, I’ll make and fit one) or can they go straight on to the wall?
Yes that is one solution I passed by a DNO tails connection chappy and his reply/opinion he robustly and perhaps pedantically he rotorted that such switches have terminals actually marked as "L" and/or "N" etc therefore could not be used for other purposes
- obviously my thoughts were, in essence, a 4 pole isolator could be considered the equivalent of two 2 pole isolators interlinked thereby one switching the normal domestic mains and the other switching the off peak mains and thereby all combined achieving full isolation of both of those single phase supplies using one switch action
- I was disappointed with his conclusion - I thought I had bright idea until he countered it.
I was also a little mindful of a possible make/break offset time in milliseconds might be an actual requirement in practice but I did not mention this feature as he might have used it as more amo to counter my query with him!
... BS7671 (compliance with which is not 'mandatory', anyway!)
On the left or the right it's going to mean the thick cables being dragged over others
Flexible double insulated singles are available, including rubber which is more flexible than tri-rated. I cleared some stock out quite recently.Flexible meter tails help with routing.
The aren't as bendy as tri-rated, but they are a lot more bendy than traditional tails.
Oh for double-insulated/insulated-and-sheathed tri-rated...
[ As has ben pointed out, theoretically 'insulated and sheathed' (although I'm sure you would struggle to find a sheath which did not 'insulate'!) ]Flexible double insulated singles are available ...
The ADE Concept panel takes me back. It was the first panel with remote keypad that I ever fitted.
Instead of the now usual 6 core cable linking the panel to the keypad, this early system needed a 12 core.
