Hi all,
I'm currently battening out a thermalite block wall so I can install XPS tile backer/plasterboard. The walls and inside of the window frame will ultimately be tiled.
I will soon need to batten around the window, but I just wanted to double check I am doing it correctly.
Do I just simply run the battens level with the existing blocks in the window frame as seen in my photos?
Thank you
Thank you
