Looking at my quote for new consumer unit and 3 new radials for 2 ovens and a hob, I see the electrician has quoted for MK Aspect range, 32A DP in stainless steel finish with black inserts.
three issues spring to mind on that
1) The hob is rated at 10.8kW so I had expected a 45A DP to be specified. Any reason I am wrong to assume that?
2) If 45A DP is required, MK website shows Aspect range only has oblong 45A DP and to comply with 2 m limit and find space on walls, a square DP is the only size which will fit.
3) MK website shows Aspect range only has 20A DP and 45A Dp no 32A DP. Mistake by sparky or MK website?
So assuming MK Aspect is not the answer, can anybody suggest a good quality make which has stainless steel / brushed chrome / Nickel finish (preferably with black inserts), and which has a square 45A DP as well as square 32A DP, FCU and switched sockets?
