I have nearly re-wired my house, and just left with a few questions before calling in a firm to inpect and test. So appreciate if someone can help.
1. I have used a 10mm Green and Yellow earth cable to earth bond from the Earth terminal (situated between the main fuse box and the electric meter) to the copper pipe on the gas meter and mains water copper pipe entering into the property from the cellar. Is this OK?
2. As part of the regulations do I have to earth the bathroom and radiators in anyway (all the pipes are copper)? If so what is the method and cable size to be used?
3. I have earth bonded all the copper pipes directly underneath the condensing boiler using a 10mm Green and Yellow earth cable. Is this OK?
Is there anything else that requires earth bonding?
Many Thanks,
Mr Electric
Many Thanks,
Mr Electric
