- Joined
- 19 Jul 2007
- Messages
- 5,948
- Reaction score
- 1,144
- Country
Why did you replace motor and pump??
i did get another copacitor but it was a second hand one that a plumber had in the back of his van so i guess it could be shot i do have a volt meter but am not sure how to check itHave you checked the capacitor with a meter to make sure it is 4uf.![]()
It has to have a capacitance range (not all do)!!
I would bet a pound to a pinch of sh#t that capacitor is fuc#ed!!
Why did you not get a new one for a few quid first, before motor etc![]()
i Replaced the motor and pump because of the buzzing i was told by an engineer that it was probly a weak motor caused by a warn pump and advised me to change them both so i did but i still have the same problemonly thing left is that coupling i guess.
Thanks i pretty sure fan is not jaming on anything i moved it slightly away from casing because like you say it can catch the resistance feels like compreson sort of like a small piston compressing air when it reaches top dead centre then goes loose again
