Wiring Shower
7 Jan 2008
Birmingham
To avoid pulling up floors etc to run a new shower cable, I am routing a 10mm twin & earth from the consumer unit, through the outside wall of the house, along the outside wall at 7ft height to re-enter the house at first floor level, then up to a 10kw shower in the bathroom. The external run is inside our roofed over and enclosed side passage. Total cable run length is 10M. Do I need to run this cable in a conduit or is it ok exposed and clipped correctly to the outside wall at 7feet high? Help would be appreciated.
just lift the floorboards and stop messing about..
if it goes outside it needs to be in conduit to avoid mechanical damage.. ( ladder leant against the wall to repair roof etc.. )
Thanks, in my case the inside route is covered with carpets under fitted furniture etc so outside is much quicker. Is tubular plastic conduit the right one for this?
Quicker isn't best
Have you notified your LABC about your proposed work?
yes he could, but that's not what he asked..
also, 10mm² SWA is more expensive than T+E, and will be a pain to terminate in the shower... :lol:
