I've had an oil boiler with a riello burner for 13years. No trouble until 2years ago it was not firing up every time heat was called for.Kept cutting out and reset button had to be used very regularly.
I'm sure you have the same problem.
Capacitor OK, they hardly ever go
Dismantled motor etc several times to no avail until I decided to get a new coupling....Much cheaper than a new motor etc.
Fitted coupling and reinstalled burner within 30 minutes.
Never failed yet. Works like a dream. Never had to touch it since.
The boiler is a Camray
QED
when i put new pump on i set pressure to same as old pump 100psi and air shutter was not moved. someone said to me today it could be a weak lockout button or control box. I got home from work every thing was ok all fired up for ch and hw ill see how it goes in the morning i guess, might get up early to see whats happening
you had no way of knowing the pressure, and stop listening to old wives, weak lockout!! total bollo rot
and as a temp fix slap some fire cement on the leak.
oilman i also have hot air escaping between the collar and flange any ideas ? do i need to replace them aswell? air is escaping left side of burner but not right side may be something getting hot
Thanks for every ones help so far ill buy you all a pint
arfee said:Capacitor OK, they hardly ever go
whatdoiknow said:you had no way of knowing the pressure,
how did you do that then? it wasnt running remember?
and by the way 100 psi is a minimum figure for a nozzle to atomize oil at
