Gas pipe size .
11 Jan 2008
Northamptonshire
we have just had a new boiler fitted plumber has installed all gas pipes he has come from the meter in 22mm then changed to 15mm he has teed of the boiler supply for my new cooker in 15mm as well , but when boiler cuts in and out flame on cooker gets a lot lower .
is this normal ?? never had gas until now
Absolutely not... Get him out to sort it out....He was CORGI wasn't he?
so he has got it wrong OR the meter governor has given up the ghost
call him back asap
sooey
yes i am for real take it hes not done the job right . if so who do report him to .
i dont like rip off merchants
He may have been right but the governor may have failed
give the bloke a chance to put it right before you pass judgement
thanks corgiman
I have tried calling him but no reply
Should i get BG to check the whole lot out ??
British Gas is now just another ( more expensive ) company!
During this cold weather we can be quite busy and you should expect that it may be a day to two before he can call you back.
Leave a message for him or write and explain the problem. Ask him to telephone you, say, within three days to be reasonable.
Obviously the gas pipe is undersized but you MUST give him the chance to correct it before taking any unreasonable action.
If you privately email me through my profile to give me his CORGI number then I would be happy to contact him on your behalf.
He has to do the job properly but also you should follow the correct procedure to enable him to sort it out first.
Tony Glazier
i take it he can check the meter ??
just so i know
There's a lot of things he needs to check to ensure that each appliance receives the correct supply pressure.
Call him back, and if you are still not satisfied get CORGI involved. - If the job is up to standard he has nothing to fear, but if it isn't CORGI will ask him to carry out remedial work to sort it out.
thanks Tony
i have left a message today on his land line and mobile .
i will give him some time to reply at least the house is warm for the first time in 15 yrs .
i will let you know how i get on , thanks
I still think he may have got the pipe sizes right but the governor has died
it has happend to me just after an install before when I left the working pressure is spot on
get the call and when i get back the WP is 13!!! dead governor
so please dont condemn the man just yet.
