Hi All,
We've recently had some new internal doors fitted. I don't know what type they are but they look similar to the one in the picture below.
http://www.wickes.co.uk/Multi-Purpo...oor/invt/200600&temp=largeimage&layout=popups
They are about 33mm thick and consist of a normal wood?? middle that is about 28mm thick, sandwiched between two darker layers of thin material, each about 2 to 3 mm thick. The face of the doors are white. I'm sure you experts know by now exactly what I'm talking about!
These are brand new doors. My questions are,
1) Do I need to use a primer first or an 'undercoat' for the type of door described?
2) Which option would you recommend - Dulux Once Gloss at £11 or normal Dulux Gloss at £10 with 20% extra free?
3) If Dulux Once, then would one coat be fine?
4) Any recommendations for a paint that doesn't go off-white/yellow after a while would be good. (There are no smokers in the house.)
5) I am concerned about the harmful effects of inhaling the paint. Would the following mask suffice?
http://www.diy.com/diy/jsp/bq/nav/n...refview=search&ts=1207003653894&isSearch=true
Thanks.
Thanks.
