Tingle from Dishwasher + light switch
24 Jul 2005
I had my house re-wired about a year ago but have been decorating most of rooms so have removed + refitted a few sockets some sockets i leave hanging without the earth connected.
I'm doing the kitchen at the moment and fitted a new dishwasher today and when i run my hand over it i got a very slight tingle.I had a read on the forum about bad/no Earths so i connect all the earths back to the sockets and the Tingle has gone.
I think the light switch may be the earth no connected again in the loft
My question is
Is it normal to get the Tingle when the earth is not connect and me reconnecting the earths stopping the tingle is that just Masking the problem
thanks nyck
I think you shouldn't stay up so late ,as it seems you need some sleep you grumpy git
Thanks for the advise a great help
It is potentially dangerous too.
You should never power a circuit on with the earth disconnected, if there is a fault then the normal fault path doesn't exist which would normally cut the supply.
Things like dishwashers may have mains filters in them which are not a problem when the appliance is properly earthed. However they can cause a rise in potential on the exposed metalwork if no earth is present.
I think the reply JohnD gave was straight to the point.
The earth wire is there for a purpose not merely for decoration.
Luckily for you and yours you just got a tingle THIS time not an electric shock or worse!
I have recently been painting the guttering. the roofers left a safety-rope fastened to the chimney, so I made a noose in the end and fastened it round my neck. I was not using a ladder, and I noticed that when I was hanging off the guttering with one hand, the rope chafed my throat. Have I got a faulty roof, or is this usual?
Don't worry, your roof is not faulty, you simply mis-read the instructions. You need to hold on to the guttering with both hands and put the paint brush in your mouth. The only time it is permitted to remove one hand from the guttering is for a tea break.
Not a paint brush, an orange.... :wink:
If only its was true? :lol:
I don't think that JohnD is stupid enough to put his life in danger because he is too lazy to connect an earth wire.
Oh, wait....... :roll:
You are a danger to yourself and others.
You are too stupid to do anything.
Keep away from all other lifeforms
