RCBO, single pole only.
An RCBO is an RCD and an MCB in one.
It does the job exactly the same as two seperate devices wired in series would.
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
An RCBO is an RCD
415.1.1
The use of RCD's with a rated residual operating current (I delta n) not exceeding 30mA and an operating time not exceeding 40ms at a residual current of 5 x I delta n is recognised in a.c. systems as additional protection in the event of failure of the provision of basic protection and/or the provision of fault protection or carelessness of by users.
No mention of single or double pole requirements.
Have you seen something which specifically mentions double pole?
There, I've saved you scrolling up the page, That is what you said and the letters RCBO are not there -are they.
I typed that, didn't say it!
So, according to Homeslaw, unless RCBO's are specifically mentioned within BS7671:2008 they're not fit for use as additional protection.
RF you said "An RCBO is an RCD and an MCB in one." I agree with you entirely.
I think you're another who needs to stop being stupid and read what has been said.
Don't resort to name calling, it's pointless over the internet.
You've just admitted that an RCBO is an RCD and an MCB in one so why can't an RCBO fall under 415.1.1?
I havent responded to that point in any shape or form why not admit you made a mistake, instead of making childish comments like "I typed that, didn't say it!"
You just don't get it do you? I have feeling you could go into an empty room and come back out with two black eyes.
I can't find any requirement to disconnect on both pole for auto-disconnection, but just asked because RCD's come as double poled.
I do see an RCCB having a BS EN 61008-1 number and RCD's having a BS EN 61557-6 number.
Making a RCD different to a RCCB (which has a different name to a RCBO of course).
Surely the big book should cover ALL protective devices currently on sale?
The 16th edition gave a title of Residual Current Device to BS4293, BS7071, BS7288, BS EN 61008-1 and BS EN 61009-1. (412-06-02 (ii))
A Residual Current Device is an RCD.
Guess what a BS EN 61009 is? It's an RCBO.
http://www.tlc-direct.co.uk/Technical/Distribution/RCD.htm
RCD is just a generic term. It covers a whole range of devices including RCCB, RCBO, SRCD.
What most people refer to as an RCD is an RCCB.
Clicky
