Anyone know if the screws that hold the MCBs in a Wylex are philips or pozidrive?
If youmean attaching mcb to busbar and connection points most CU's seem to have a head that is 50% slotted and 50% phillips. CK do a special screwdriver for this called modulo.......buy it if you are in the mood to treat yourself although I've never had a problem with a PH2
I don't mind Torx per se - just drives me mad that I can't look at one and have a clue how big it is...I agree. I hate Torx. Even more I hate a mixed screw set up.
and if your not picky; it only takes one knife. (joke)If you're picky and use the right tool for the job it takes three screwdrivers to replace a plug top![]()
