Hello electricians. I'm doing my AM2 tomorrow and the main thing that's bothering me is the motor. Here is the diagram:
http://www.net-works.org.uk/figurec.asp
http://www.net-works.org.uk/figureb.asp
It's all wired in 1.5mm singles, just wondering if anyone could tell me if it's all got to be in brown singles (obviously apart from the earth) or if some links etc have to be in black/grey, and where the neutral comes from the left up to the green neon, if the neutral carries on past there or if that's the only neutral in the circuit. Also, I'm fairly sure where all the parts on the motor diagram are in the main layout but I'd like to check:
Coil (A1 and A2), Hold on/start (63 and 64), Stop/reset (96, 95, 97 and 98) and the 13-14 in the main starter and the fuse at the top right in the fuseboard, is this all correct?
Also, do the black/grey have to be brown sleeved in the light switches, and what singles do I have to take from the TP&N 20a s/fuse to its socket.
Any help would very very very very much be appreciated cause im slightly bricking it.
