Not much on google so I thought I'd start something for it to pick up.
I bought the largest version on ebay. It had 15% off for a reconditioned unit making it £330. This is as cheap as it comes unless you buy Evolutions 'Rage' electric thing. It arrived in two days by Palletline, so excellent. Although the box was retaped all of it appears to be brand-new. I can see no signs of use.
When assembling the bolts aren't the sizes specified in the manual and two washers are missing. It makes no difference though and what's there works fine.
For adding oil again the manual is hopeless. There's a oil filler at the front and it's really hard to get open as jammed against the belt guard. I used grips. Then I found there's a second oil filler at the rear, doh! You can't make out either from the manual.
Also in the manual, the choke lever is completely different.
Engine started very easily. I'm surprised how the 84kg isn't too bad at all with the wheels. With a 192cc engine it has plenty of power and a big plate so you won't be wanting here.
I have queried why the wacker is out of alignment. There are bolts on either side but I haven't touched them. Maybe wackers are supposed to be like this or maybe adjustment of the bolts is required. There's nothing in the manual about it. I'm awaiting on them to get back to me.
So far so good. Quality is decent I feel like it's a good buy.
